self serve
Rose2013
where do we find this self serve
@Rose2013   All support is online via messaging either by clicking the chatbot bubble bottom right of the screen and submit a ticket or send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Also you should remove your tel. number from your post by clicking the 3 dots (top right of post) as you're on an open public forum.
Lidzzzz
It's just on the upper right corner: "My Account". After clicking it, it should direct you to the login page. You can choose to set up an account if you don't already have one.
Or if you have trouble finding the button, you can click on this to direct you to the page: https://selfserve.publicmobile.ca/
Rose2013
The problem was solved. Thanks!
Self-Server also called My Account, just the "My Account" link on the very top right of the page
Public Mobile - Account Log In
