01-19-2018 10:26 PM - edited 01-04-2022 03:21 PM
01-21-2018 09:06 AM - edited 01-21-2018 09:06 AM
@bob18 have you contacted the mods asking them to look into your account? i think that is your best/only option.
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Additional Useful Information:
01-21-2018 08:49 AM
Now I can't make calls, it's saying talk is not included in my plan. My next payment date is February 18. This is driving me nuts.
Thanks you all for ur help
01-20-2018 03:45 AM
@bob18 wrote:hello there I choose the $20 plan; but every time in insert the sim, it keeps telling me no service.
what do I do?
A "no service" message in your phone's notification area usually means that either your sim card isn't active, or that it's connected to a network that you can't use (although "emergency calls only" would probably be a more common message for that).
01-19-2018 10:36 PM
what do I do?
What's the brand / model of your phone?
Did you bring it from another provider? Which one?
01-19-2018 10:32 PM
@bob18, how long has it been since you activated your account? What do you mean by 'every time I insert the SIM'. You should insert it and leave it there. You can try to reboot the phone once. After that, check your network settings. The phone might be manually set to another (previous) provider. Try setting to automatic. If that doesn't work, and Pblic Mobil is available, try selecting that.
