roaming
surefoot1
I am going to the USA for 4 days and the roaming plan is 15 days.  How do I get it to revert back to Canada after I return?
What make and model phone?
surefoot1
Thanks so much.  I appreciate your help.  I don't know what "volte" is or how I would know if PM has enabled it on my phone.  How would I find out??
hairbag1
@surefoot1
there's nothing for you to do once you get home. Your cell will just drop T-Mobile at / near Cdn side of border and take up PM. You're balance of Roaming days will continue to count down until 15 days have elapsed.
When you get to USA, make sure you're connected to T-Mobile as no others will work. If PM has enabled volte on your phone you likely won't have any probs.
Yummy
Verify it is connected to PM instead of T-mobile
dust2dust
If you're on automatic networks then it's all seamless.
