rewards
tire-man-bill
can i purchase additional data with my rewards points?
imanno
yes there are a few options. look at the list of rewards and you will find it.
Phil_Adelphus
@tire-man-bill   Yes you can starting at 5 points and going  up to about 20 points I think.  If the site is down you can't look but otherwise log in to your account, go to My Rewards and peruse the catalogue there.  Make sure to look carefully at each add-on's details because I think some data is for US and some is for Canada.
turtleTurtle
Yes you can. I just went to check the rewards page, but it says it is down for maintenance... So check back later to see the amount.
Alternatively, you could buy data add on and redeem for $15 off your bill to pay for the add-on...
Points can be redeemed for account credits in 15 points for $15 increments.  Also, check to see if there is a discount in the points catalog being offered on the desired add-on.
