02-03-2021 01:52 PM - edited 01-05-2022 05:08 PM
i want to retrieve my contacts from my sim card.my old phone is damaged so i transfered my sim card to another phone but my contacts are not coming up on my new phone
02-03-2021 09:35 PM
@chairman wrote:i want to retrieve my contacts from my sim card.my old phone is damaged so i transfered my sim card to another phone but my contacts are not coming up on my new phone
Did you have the names and phone numbers saved on the SIM cards. These days, this is rarely done as only a name and phone number is saved and each phone number gets saved as a seperate entry. Some phones have this disabled, but look for a setting in your contacts menu/app to do something worded somthing similar to "show SIM contacts".
02-03-2021 02:05 PM - edited 02-03-2021 02:08 PM
I believe you can, @dabr (EDIT: as i now see you've also since determined 👍)
My device appears to have the capability to store/move contacts at 4 possible locations. I can't speak to the OP's situation, however.
Phone manufacturer account, phone memory, SIM card, & Google account
02-03-2021 02:01 PM - edited 02-03-2021 02:02 PM
.. this is what it looks like on an Samsung phone, just change to SIM and you still see all the contacts stored on the SIM
Then, you can also open each contact, and there is an option to copy it back to somewhere else (phone/Google, etc)
02-03-2021 01:59 PM
Are using an Android phone ?
Here are some tips.
https://www.coolmuster.com/android/retrieve-contacts-from-sim-card.html
02-03-2021 01:58 PM - edited 02-03-2021 02:02 PM
@chairman Edit: after googling this, apparently a SIM does store contacts, so nvd!
Do you have gmail account? Try signing into your gmail account on your new phone and see if the contacts list gets updated too.
02-03-2021 01:55 PM - edited 02-03-2021 01:58 PM
On my device, there is an option to search contacts within Google Contacts or on the SIM device or on the phone memory itself.
Make sure you've selected the appropriate contact storage location to display the contacts you're seeking.
I believe there's also an "All" selection which is what I have set.
