reset account password
MarieRyer1963
Tried to sign into account.  It said to call for support, however when called they said we had to go to community support
2 REPLIES 2
JL9
You can also direct message CS_Agent if the forgot password link doesn't resolve this for you.
dabr
@MarieRyer1963    Have you forgotten your login password?  Did you try the forgot my password link?  You can try the link to see if you can recover your password here:  https://selfserve.publicmobile.ca/forgot-password/
If still unable to login, then submit a ticket for a password reset via chatbot here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
