regarding payment for re-cycle
samkc1697
Hi there,
i'm having issues with my bill as my bill for the 13th of may when my plan re-cycles was $28 with rewards. I just paid it off because i thought i would get a re-cycle of data casuse i've run out and it now says i need to pay $40 on the 13th of may? Could you please help me with this confusion?
Thank you,
regards,
sameer
2 REPLIES 2
samkc1697
Thank you very much for your help.
will13am
@samkc1697, there were issues with account payments a while back and the problem has since been dealt with.  Perhaps your account remains affected.  Can you please check your payment history to ensure things are in order.  If a problem is confirmed you will need to see moderator team assistance to correct it.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
