03-06-2024 11:54 AM
I just registered my PM account but didn't see option to fill referral code. Am I missed it somewhere? The code says up to $50 irresistible...
03-06-2024 04:23 PM
Yes maybe. I filled the code and see what would happen.
03-06-2024 04:19 PM
Just so you know, you will only get $10. The person who told you $50 is not being truthful!
03-06-2024 04:18 PM
No code gets you $50! It's a lie to get you to use that referral code over someone else's. Only $10 will get credited.
03-06-2024 11:59 AM
HI @Newton99
support agent can add it back for you. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-06-2024 11:58 AM
Code is entered on the payment page. But if you missed it, that's ok. Submit a ticket to the chatbot at the lower right of your page to have it added.
BTW, who is giving up to $50? Never seen that before
