referall Q
Rpullar
Just signed on with public mobile this week, and already have a friend that wants to switch over from freedom. I Went to walmart when switching my two lines from koodo. Can He also go to walmrt to switch and still use the referall or can referals only be done online?
Thanks
will13am
@Rpullar, it is imperative that the referral be applied at time of activation regardless of where the activation is done.  The referral cannot be added after activation is complete.
meocon
@Rpullar Yes he can go to Walmart to activate a new sim with PM & port his number over on Self-Serve, he can use referrals at Walmart. He has to let saleman at Walmart knows he has a referral number from friend.
Dougmania
Referrals can be done at walmart.
The form is almost identical when at the walmart kiosk when activating.
NDesai
@Rpullar I am pretty sure you can tell Walmart rep to enter referral. It is done by using a phone number that is activated/transfered on Public Mobile.
