Referral code at registration
golhamreza
Hi there,
My friend referred me here but when i registered my account , i did not see a chance to add the referall code. how can i add it now.
Thanks
Kydd
Did they send you a referral link an you used that link to sign up
Unforttunately, the code did need to be entered during the activation process.  There's no guarantees (and the answer could be no), but for consideration, you'd have to open a ticket using the chatbot.
  If the ticketing system in the chatbot gives an error message, then send a private message to CS_Agent.  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@golhamreza
it is at the payment step, there was a box there for you to add friend referral code
But you can still ask support to add it back for you now.  Please engage them by direct message:
