10-27-2023 09:10 AM
I just signed on with Public, the SIM card i received is the wrong size. I need a Nano, received standard, was not asked what size I needed when I ordered it. Help, please! Thanks.
10-27-2023 09:28 AM
10-27-2023 09:15 AM - edited 10-27-2023 09:16 AM
It has a breakable edge which you can push out to be a nano sim to fit your phone
10-27-2023 09:15 AM
@RyMe The sim card comes in once piece but in reality is in 3 sizes, for the nano you just remove the outer parts leaving the size you need
10-27-2023 09:14 AM - edited 10-27-2023 09:16 AM
@RyMe it is a 3 in 1 sim card. There are frame around to remove to make it a aller
Please check
added: image
