“re-provision / network registration refresh” immediately
Rhea7
7 REPLIES 7
Have you login My Account or the app and confirm if your account is active?
and since it is a physical sim, did you test your sim card using another phone?
or get another active sim card to test on your phone to confirm if it is a phone problem
@Rhea7 wrote:
It’s a physical SIM card and the phone is in SOS mode. It’s saying no sim provision.
Have you logged into your account and confirmed the latest payment has gone though? Sometimes autopay can error and miss a payment causing the SOS mode.
hi @Rhea7
for physical sim, you can reprovision without asking PM agent.   A quick way to reprovision a physical sim is to put your sim on another phone.  Try it
And also, check if your phone is blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
Rhea7
Socrates8567
When you hear the term reprovisioning, it means resetting or re-syncing your SIM card / eSIM profiles on the network's backend towers. This forces the system to rebuild your cellular connections from scratch, which is incredibly useful if your data abruptly stopped working, if incoming calls aren't ringing through, or if SMS texts are stuck.
Because Public Mobile is a self-service brand, you cannot fully reprovision an account yourself—only a Customer Service Agent (CSA) has the backend network tools to do a deep system reset.
However, there are a few powerful tricks you can do right now to force a network refresh from your end, as well as the exact way to get a support agent to do it for you.
Before messaging support, try these forum-tested tricks that often force the local cell tower to re-sync your device.
Turn your phone completely off. Take your physical SIM card out, put it into a completely different phone, and turn that phone on. Let it pick up the Public Mobile network signal for about 5 minutes, then put it back into your original phone. This forces a brand-new "handshake" between your SIM card and the network towers.
Instead of a fast reboot, turn Airplane Mode ON and leave it on for a full 10 consecutive minutes. This allows the network switch to officially flag your device as "disconnected." When you flip Airplane Mode off, it forces a hard reconnection rather than a soft cellular handoff.
Log into your My Account portal via a web browser. Go to your subscription settings and temporarily report your phone as Lost/Stolen. Log out of your account, wait 5 minutes, log back in, and click Resume Service. This cycles your status on Public Mobile’s database, resetting your plan flags.
If the DIY steps don't fix the issue, you will need an agent to rebuild the system parameters for your phone number. Links have already been provided.
Chalupa_Batman
Hello @Rhea7
What issues are you having?
Sometimes, if you place your phone into airplane mode for 1 minute, then turn it off and reboot... that tends to solve most issues. Even resetting your Network Settings.
But once again, it would help if you shared what issues you're having so the community as a whole can help you.
hi @Rhea7
if you have an esim, quickest way to re-provision is to get a new esim using the app
or if you want PM agent to help, you can submit  ticket by direct message:
