04-08-2023 08:26 AM - last edited on 04-09-2023 10:57 AM by Dunkman
Tried to call PM Canadian number from my Canadian PM number while in London, Ontario. Get a message that call cannot be completed because I do not have a US roaming package add-on. But I'm in Canada, with a Canadian phone number, calling another Canadian number. Public Mobile to public mobile call. Both my number and the number I'm calling have the same first six digits. Maybe just a coincidence.
Tried calling another PM Canadian phone number and it works fine. Completely different area code and prefix. What's going on with public mobile?
Try the usual restarting the phone. Nothing seems to work. Any ideas?
04-08-2023 02:47 PM
Public mobile is known to have various glitches and incorrect messages. If your friend's accounts are inactive, that would explain why the call won't go through. However, the message is still an error. Not sure whether this is a factor, but Public mobile has been starting VoLTE services slowly for existing customers. There have been more talk issues the last several weeks.
04-08-2023 12:54 PM
It appears that the PM customers I am trying to call (husband and wife) may not have their accounts up to date ($) . I don't usually get this message when that happens though. These are the only two numbers (PM or other) that I am getting this message with.
Has anyone ever heard of this happening?
Tried everything recommended from my end. All other calls in and out are successful.
04-08-2023 12:49 PM
@Maxoman you don't see Public Mobile as a choice?
when you picked Telus, it connects? you cannot make the call at all? or it gives you that US roaming error again?
We had a similar issue yesterday and it worked after once more phone reboot.
So, try to reboot your phone once more. When it is back, make sure the network selection is still manual and Public Mobile is selected (or if you don't see PM,use Telus)
tell us if it works
04-08-2023 12:44 PM
No where near the USA. Selected Telus as network.
04-08-2023 12:43 PM
Selected Telus... Shows PM as network. Still no calls going through.
04-08-2023 08:33 AM - edited 04-08-2023 08:35 AM
When you get that message, it's most likely because your device is trying to pick up a USA mobile network tower which it may be trying to connect to. (which is odd being in London, Ontario 🤔)
Go into you network connections, and manually select Public Mobile (or Telus) from the list of available network operators displayed as opposed to letting the device automatically detect networks.
Then try that call again.
04-08-2023 08:32 AM
@Maxoman maybe your phone is connected to the stronger US signal
First reboot the phone and see if it can connect back to Public Mobile
If not, go to the Network selection on your phone. Change from automatic to manual connect and pick Public Mobile as the network. It should work that way
