"Dumb phone" (i.e. non-smartphones) Suggestions for PM + "Dumb phone" Compatibility
cc123
Hi All,
I recently ordered a PM SIM card and am having a tough time finding a new "dumb phone" (non-smartphone) for PM. I am hoping for suggestions on "dumb phones" that are PM compatible and which can easily be bought new online (less than 100$ CAD).
So far I have found these phones and am not sure which are compatible?
- Jethro SC318v2 - 3G Bar Style --> Bands: 3G WCDMA 850/900/1900 Mhz, 2G GSM 850/900/1800/1900 Mhz
https://www.jethroshop.com/product-page/sc318v2-with-free-30-day-plan-3g-bar-style-1
[Could not find in PM compatibility checker]
- Jethro SC435 - 3G Slider Style --> Bands: 3G WCDMA 850/900/1900 Mhz, 2G GSM 850/900/1800/1900 Mhz
https://www.jethroshop.com/product-page/sc435-with-free-30-day-plan-3g-slider-style
- Nokia 3310 3G --> Bands: GSM 850/900/1800/1900 + Band I, II, V, VIII, RoW2
https://www.bestbuy.ca/en-ca/product/unlocked-nokia-3310-3g-charcoal/12533827
[Found "Nokia 3310" (excluded the "3G" part) in PM compatibility checker = Not Compatible (?)]
Thanks in advance for any additional compatible phone suggestions/confirmation of the above phones' compatibility.
2 REPLIES 2
Bubba
I will have to start looking for a "dumb" phone for my impaired family member.
Jethro SC435 - 3G Slider Style is available at walmart
https://www.walmart.ca/en/ip/Jethro-SC435-3G-Unlocked-Slider-Style-Cell-Phone/PRD2B7P770IFQN5
rhbcc
https://store.publicmobile.ca/products/triple-punch-sim-card
check out this link - the sim card should work because you can punch the sim card in your phone according to the required sim card size (standard, micro , nano)
the Nokia 3310 you are referring to uses a micro sim.
SC435 and SC318v2 uses micro sim as well if I'm not mistaken.
