purchased the wrong data add on
Newfiegrl
I purchased the us roaming data add on in error...is there anyway to fix this to purchase the Canadian data add on
Thanks
Acekiller
The mods are pretty good at resolving issues like these!
collin1215
Best to private message a moderator. @CS_Agent and provide them with your account number or you could message their Facebook group - https://www.facebook.com/PublicMobile/
If you contact mod more likely thry can either change the add on if you looking to add add on if not then thry will probably give you a pm credit which can be used for next renewal and remove the add on that you bought mistakenly
** I am not a Mod, please do not include any private info in a private message to me.**
ShawnC13
@Newfiegrl, sorry to hear about your issue.  You will need to private message a moderator and see if they can get this fixed up for you.  Here is where you will find out how to contact a MOD  http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
CaNuCk07
@Newfiegrl  send a private message to the moderator team, and they will be able to assist you.
@CS_Agent
