10-24-2025
01:14 PM
10-24-2025
07:25 PM
computergeek541
Hey i got locked out of my sim and have been tryimg to find a away to call or get support. Is this the only way?
10-24-2025 01:17 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM Card, SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/xYpc_I
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
