07-01-2026 09:40 AM
I bought sim card from Amazon, put it in phone to ensure it fits, works and was not damaged. It stated I have 29 days to activate with 2 gb wifi. I will not be activating until August after activation deadline. I have not registered or subscribed to a plan yet until August. Can this sim be activated after that date in store, online with another wifi source other than public mobile? Any other suggestions?
07-01-2026 09:48 AM
as long as the sim hasn't ever been activated with Public Mobile; it can be activated next year, if you wanted to. It's your plan that has a 90 days window. You need to activate by downloading the app to your cell, create your acct, select a number and finally activate the sim.
07-01-2026 09:45 AM
hi @Husker if it is a new subscriptions you have 90 days to complete the activation
if you are worry, ask PM agent to confirm
you can submit ticket by direct message:
