public mobile plan
Vyas
How to check my public mobile plan & change other plane.
hairbag1
@Vyas
use a laptop and log in to your account. Click on PLan & Add-ons...you'll see details of current plan AND a tab that says Change My Plan. Click that and you'll find the plan menue. First click 3 G or 4G...then use the little down / up arrow to scroll through the options. Once you find something you want, decide if you want to Change Plan on renewal date OR Change plan now. Best to select the first option.
LitlLdy
@Vyas , sign into your account to view your plan. Select Plan & Add-ons, select the plan you want,  Change plan on renewal date.
Account Sign in!
pmbc
@Vyas sign into your account.  Click the plan menu on the left hand side and you can see your current plan and available plans to change to.  if you decide to change, change it at the next renewal versus immediately if you want to use the rest of the current plan.  There are no refunds or credits for. whatever time may be left on the current plan.
