04-10-2022 02:49 PM
Does public mobile have coverage all over Canada or there are some places that it does not have coverage?
04-13-2022 02:14 PM
04-13-2022 02:14 PM
Thanks
04-13-2022 01:45 PM
Not a particular place
04-13-2022 01:28 PM
I don’t want it for a special location. Just wanted to know which location have better coverage
04-11-2022 09:58 PM
I was just speaking about the coverage. HSPA coverage will be the same as voice
04-11-2022 06:53 PM
@HALIMACS wrote:On the other hand, probably well over 90% of the normally populated areas has coverage.
According to: https://www.telus.com/en/partner/network#Partner%20-%20Mobile%20Network%20Tab%20-%20Our%20Network
"Our coast-to-coast 4G LTE network covers 99% of Canada's population, with LTE advanced (LTE-A) technology covering more than 93% of Canada's population."
04-11-2022 12:36 AM
@gpixel wrote:go to telus' coverage map and disable "5g" and "4g LTE". this will show PMs voice call coverage. enable "4g LTE" to see PM's data coverage
https://www.telus.com/en/mobility/network/coverage-map
Data will also work on the HSPA network.
04-11-2022 12:23 AM
04-10-2022 07:18 PM
Where are you located?
If there are Telus cell towers or offers Telus TV, internet and landline in your area…then you will have coverage.
04-10-2022 06:41 PM
04-10-2022 04:21 PM
There are MANY places that have little or no coverage.
Probably 75% of the total land mass of Canada would fall into that category.
04-10-2022 03:35 PM
Hi @Nadia2021 Not really all over Canada , but pretty much all major cities and towns. Some area is on the coverage map but the reception not great. Any particular places you are looking for??
04-10-2022 03:29 PM
It's pretty expansive yes. I don't think there would be a situation where other providers have more coverage since it's the Telus network, unlike some of the issues Freedom has been know to have
04-10-2022 02:51 PM
Here is a link for a coverage map.
https://www.publicmobile.ca/en/bc/coverage
Canadian Cell Towers
http://www.ertyu.org/steven_nikkel/cancellsites.html
Telus and Bell towers:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Network
-sharing-explained/td-p/129092
04-10-2022 02:51 PM
The bottom of every page here has a link called Coverage. Like all providers there would be blank spots.
