problems
abassm1998
i have problem i can call and send masseges but no one can call me or text me how can i solve that? and what is the problem?
popping
If you just port your number from other provider, this is the detailed explanation why you cannot receive calls or texts.
Number porting is a 2 stage process:
Stage 1. PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider.  If your old SIM card is still working, you can continue to use it until it stops working.  Then, switch to use your new PM SIM card as your port is completed.
sunflowershine
@abassm1998 Seemed your porting is not completed yet. Once it is done, you will receive a text message to notify you the porting is done! Welcome to PM!
Did you just recently sign up and activate and transfer a number from a previous provider?
If so then these things can take some time. If so you can keep using your old SIM until it stops working at which point that should be how you know the new SIM should be ready.
bravo_md
Did you just port over an old phone number?
