porting number from koodo prepaid
devotiby
Hi,
I want to port my koodo prepaid number over to my pm sim. Messaged the mod team 4 times over the last 4 days but no response. Am I supposed to contact someone else?
popping
@devotiby wrote:
Hi,
Send moderator another private message as you had waited long enough.
I sent a private message to moderator two days ago and I got help this morning (42 hours after I sent my private message for support).
Jeremy135
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 Is the link try again, mine took a few days to fully switch over when I went from bell to public
@devotiby wrote:
Yes thats who I've messaging for the last five days. Does this usually take this long to get a response?
Unfortunately these days yes. But once you're in and settled it would only be on rare circumstances that you would need them again.
devotiby
Triguy
  • If you are transferring from a Koodo prepaid plan you will need to select a new number at activation, create a Community account, and then send a private message to our Moderator Team here to complete the transfer to Public Mobile.
Here is more info about porting.
https://www.publicmobile.ca/en/on/get-help/articles/choose-your-phone-number
You may need to message a moderator again.  It can take 48-72 hours for a response.
@devotiby wrote:
Hi,
Was it the username Moderator_Team?  A link to contact them is here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
That is the only way to contact customer service. Hopefully, they get to you soon.
