11-07-2021 09:42 AM - edited 01-06-2022 03:58 AM
Hi there
I moved Public mobile yesterday and requested my number -780-xxx-xxxx be ported over. I did not respond from my previous carrier's text to allow the port within 90 minutes, I did respond but after the allocated time. I called my former carrier - freedom to enable the port, and then informed my to reinsert my old sim and respond to a text which I did.
I seem to be having issues still receiving calls to this number and receiving all my texts send from people wishing to contact me via text
Edit by Dunkman: removed personal information
11-11-2021 10:52 PM
11-07-2021 11:06 AM
It sounds like number porting is still underway, and has not been completed successfully. If I were you, I would get in touch with PM's customer support by either creating a ticket with the chatbot in the lower right hand corner of this page, or by sending a private message to @CS_Agent
11-07-2021 10:45 AM
if you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
11-07-2021 10:44 AM
@richardlowe if it was over 3 hours trying calling that porting phone number I private messaged you, or submit a ticket by other methods provided to confirm port is all good.
In the meantime perform a Reset of your devices Network Settings.
11-07-2021 10:33 AM
@richardlowe wrote:I am still not able to receive calls to my ported number and not all texts are getting through. Do I need to just wait for the port to finish?
How long has it been since you replied Yes to the SMS?
Have you tried the latest link I posted above?
11-07-2021 10:28 AM
11-07-2021 10:08 AM - edited 11-07-2021 10:25 AM
@richardlowe wrote:Hi there
I moved Public mobile yesterday and requested my number -********** be ported over. I did not respond from my previous carrier's text to allow the port within 90 minutes, I did respond but after the allocated time. I called my former carrier - freedom to enable the port, and then informed my to reinsert my old sim and respond to a text which I did.
For porting issues, submit a ticket to PM via :
11-07-2021 09:58 AM - edited 11-07-2021 09:59 AM
You could also try this link to reinitiate the port:
11-07-2021 09:54 AM
@richardlowe Yes, you have to reply within 90 minutes. Since you replied late, it won't work and hence you got the issue about incoming
But no worry, just call the number sent by @esjliv and PM can retrigger the process. But this time, make sure you have your old sim ready and reply within the allocated time 🙂
11-07-2021 09:48 AM
Submit a ticket this way https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Or call the porting number...which I will private message you now. Check your inbox.
Also, please edit your post to remove the phone number you posted.
11-07-2021 09:46 AM - edited 11-07-2021 09:48 AM
Try doing the following:
