port sms message
olsonite
i made the mistake of not having my old sim in the phone while porting so i did not get the port sms message to finish the transfer and it has been over 90 mins, is there anyway i can trigger the transfer sms again? without waiting for a cs agent
2 REPLIES 2
olsonite
thanks, rep says i should get another port message at around 9am pst
@olsonite  No worries I’ll send you the porting team number private message and they can re trigger the port request for you
you can use this link to your in box
