02-04-2026 03:15 PM
02-04-2026 03:17 PM
July 22? that was too far away and you just find out now?
it has been over 6 months and you won't be able to check from your Payment history (only 6 months of history there). You need PM to help
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
