plan discontinuing?
Hildegard
I am currently on a 1GB herodata --3G plan.  Is this plan scheduled to expire soon?
umnikke8
Existing plans are rarely changed here. Your plan should continue as is. Keep in mind the difference between "3G plan" which is just how fast your device is allowed to use the network and 3G network, which is starting to get shut down. All plans are allowed to use all available networks 3G/4G/5G.
ORNGNBLK
@Hildegard If you're inquiring about the use of a 3G plan,  they are no longer being offered, as 4G and 5G plans are now the standard. But since you are subscribed to the plan it wont go away without prior notice.
Some companies are removing 3G service altogether but PM, depending on were you reside still has you covered 😉
@Hildegard
Who knows when it will expires. PM normally change plans monthly.
hi @Hildegard
the plan is still there.   the plan "expires" just means you have to pay to renew.
if you have autopay, it should be ok.  But if Autopay fails, then you will just need to make a manual payment
Check your My Account and it will tell you the end date of the current cycle
