plan change today
cowwmn
#moderator
My plan expires/renews today and I want to start a different plan today but it only appears to let me start it on next renewel.  Going from $40 plan to $25 plan.  Please advise
will13am
@cowwmn, when is your next renewal?  Is it 30 days into the future?  If you are unable to execute the plan change, I suggest reaching out to the moderator team for assistance.  The moderator team can be reached via private message using this link.  Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
mimmo
If your screen says anything other than active then you can only renew your current plan. Best thing is to simply futuredate a plan change ahead of time.
EdmondY
Has it already billed for service next month?  You should have got the system to change your plan next renewal date before your plan was due today.
