08-10-2020 12:15 PM - edited 01-05-2022 12:28 PM
Hi. I want to know can I continue to use the data of add-ons after canceling the plan.
08-10-2020 03:52 PM
@cyf FYI the hint is right in the name: "add-ons" well, add on to your plan features.
08-10-2020 12:40 PM
@cyf wrote:Hi. I want to know can I continue to use the data of add-ons after canceling the plan.
You need an active plan in order to use data add-ons.
Currently, the cheapest plan is $15 but it comes with 250MB of 3G data. Then you can get all the add-ons you want.
Alternative is to get a plan with more data...the $30, $40 and $50 plans have the most, then if you still need more, get another data add-on.
Good luck in whatever you decide.
08-10-2020 12:21 PM - edited 08-10-2020 12:22 PM
08-10-2020 12:20 PM - edited 08-10-2020 12:20 PM
@cyf You need to have an active plan to use data and addons.
