phone reads not registered on network and cant make a call
12-05-2020 01:05 AM - edited 01-05-2022 05:39 PM
12-05-2020 10:31 AM
@crushton Is everything up and running now? If not have you contacted a moderator? Does the sim in your phone have the same last 4 numbers printed on it that show in your self serve account when you select change sim card?
12-05-2020 07:38 AM
Hell @crushton ,
Try one or more of the below:
*rebooting your phone
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
12-05-2020 01:28 AM
@crushton there was a network outage earlier. try restarting your device to see if it reconnects to the network
12-05-2020 01:13 AM - edited 12-05-2020 01:18 AM
Which phone are you using?
PM uses 3G signal for voice calls and uses 3G or LTE for data.
Login your account.
What is your account status?
