phone payment
12-05-2017 06:17 PM - edited 01-04-2022 03:04 PM
12-05-2017 07:24 PM
@aza123wrote:
$28 Canada-wide Talk + Text thats my plan and it says that i have 45 available funds and 45 balance.
Clearly you have enough funds to cover your plan cost. I suggest to send a private message to the Moderator_Team with your account info. They will take a look into your account and see what's wrong.
12-05-2017 07:13 PM
12-05-2017 06:57 PM - edited 12-05-2017 06:58 PM
@aza123wrote:it says to pay 10 dollar more now
Well, the system should not ask for more unless you are on a different $35 plan. What's the exact plan are you on? Do you see the $25 voucher added under Available Balance?
12-05-2017 06:50 PM
12-05-2017 06:50 PM
im on a 30 day plan
12-05-2017 06:47 PM
@Samianauman@ wrote:It' 25 plus tax. If u only adding 25 dollar then u need to top up bit more
No, taxes are prepaid when you get the voucher. So the voucher amount is 1:1 with the self-serve amount.
@aza123 Are you on a 30 days plan or 90 days? How much more the system is asking to pay?
12-05-2017 06:41 PM
