payment
19MAY64
yesterday I went to the payment section to update info for my credit card and today it shows it's still loading and I can't fix it. i would like some help please.
CSA_PM
Customer Support Agent
Hi @ 19MAY64
Was the issue resolved?
Mateen
not able to it yet still loading
@19MAY64
Try updating your CC on the PM app.
Login and go to Payment tab>Update Card Information.
If you are on the website, clear cache before login.
TheSterlinger
Yesk many has this issue. Refresh the page, log out and try again.
Did you also try the app?
You could also call 1855 4 Public to update the same cc number on file.
hairbag1
@19MAY64
mine has been doing that since late yesterday as well. Payment tab just won't load correctly. Try using laptop if you are currently using app.
