08-30-2018 09:44 PM - edited 01-05-2022 01:36 AM
What are the password parameters for accounts. I cant get into my account and the reset password doesnt work. But i think i can figure out what my password was if i know what the parameters are.
08-30-2018 10:01 PM - edited 08-30-2018 10:02 PM
39 seconds late.
@Tolerantwife wrote:Im asking what the password parameters are not how to reset the password. I know the feature is broken.
From my change password page:
Set up a password that is easy for you to remember, but difficult for others to guess. Try a combination of numbers, symbols and both upper and lower case letters.
If this solves your question, please select my reply as Solution!
08-30-2018 09:59 PM
08-30-2018 09:59 PM - edited 08-30-2018 10:01 PM
ignore this reply, apparently i can't delete replies so
08-30-2018 09:56 PM
@Tolerantwife, the password reset feature is broken. You need to contact the moderator team for password reset. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
