04-16-2021 10:03 AM - edited 01-06-2022 01:48 AM
04-16-2021 12:00 PM
@gurveinn There have been previous reports of an automated plan change failing. As suggested might be best to open a trouble ticket.
To obtain a ticket, click on https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question in SIMon. Follow / invent the prompts until you reach the Contact Us button, click on it and a Submit Ticket button should appear. To confirm that your ticket has been submitted, check the SEND box in your private messages; click on the small envelope next to your avatar at the top right of your screen.
If you have problems submitting a ticket, you can also send a private message to the moderators, but this alternative contact method may have a longer response time. Click: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-16-2021 10:18 AM
@gurveinn : What plan did you have before this renewal? Plans don't automatically change. Had you set up a plan change for that renewal?
04-16-2021 10:13 AM
You could change your plan immediately but you would lose any unused minutes, texts, or data.
You may want to contact a moderator by clicking on the bubble on the bottom right if there was a mistake in your plan.
