outbound calls
Professor1949
Calling local number, does not go through, says I do not have US coveerage
Professor1949
Problem has been rectified
Rastin
If not in the US but close to the US border try turning off roaming to stop it from connecting to ys towers.
hi @Professor1949
are you connected to US network ?   check your network to confirm you are connected to Public Mobile, or manually connect to it and try again
Dunkman
@Professor1949
More details would be helpful.
Are you in the United States?  Do you have the US-Canada calling plan or a US roaming add on?  Which model phone do you have? Is it VoLTE compatible with PM network?
Chalupa_Batman
That's odd @Professor1949 ...   try rebooting your phone and try again. If that doesn't work, try resetting your Network Settings and reboot.
