opposite of #31# for public mobile?
nutpantz
my phone setting to to block my caller id for all calls.
what is the #XX# code to unblock this call
basically the opposite of  #31# 604 XXX XXXX ( to block caller id on this call)
i want   #XX# 604 XXX XXXX show my caller id for this call only.
Careful:
dialing *31# by itself sets the "Network Default" to block outgoing caller ID, whereas prefixing *31# on a number is a one time "allow" if the default is currently set to block. (Confusing i know!)
Likewise, dialing #31# by itself sets the "Network Default" to allow outgoing caller ID, and prefixing #31# blocks it for one call...
nutpantz
works thank you.
@nutpantz
How about this. Maybe this will help.
Try *31#..
Put in *31# for the opposite
nutpantz
not helpfull
Jb456
@nutpantz
Your phone settings can only either block your number or show your number.
If you only want your number to show for one number..then simply turn off the block before calling that number and it will display. After the call turn your number back to block.
