number change
07-24-2024
10:28 PM
07-24-2024
10:39 PM
computergeek541
07-24-2024 10:43 PM
Hi @jfctir
It's very easy to do. Just log into your account online. Go to Profile on the left hand side. Then on your right hand side the third box that says My Phone number, click on the pencil beside your current number. Next page you will see options and number to change it to. Then Save Changes. It's that easy. And you can do this up to 4 times per cycle. As in month. Hope this helps.
07-24-2024 10:43 PM
You can use this link to change your phone number.
https://myaccount.publicmobile.ca/en/account/profile/update/phone-number
07-24-2024 10:36 PM - edited 07-24-2024 10:37 PM
Using the app look under account and you will find change phone number click on it and fallow the steps
