not able to receive calls
advaitranade
hello I transferred my number from freedom to public a week ago, all services are working but I'm not able to receive calls. I don't have my old sim card now.
Hello @advaitranade ,
Try one or more of the below:
*turn off your phone, leave off for at least 3 minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
If none of the above corrects this, then definitely a stuck port (see other comments above).
My friend ported over from another carrier and he had the same problem. It corrected after he powered off the phone then turn back on. He mistake was that he only turned off the screen and not powering off while swapping the SIM card.
Try that first.
HALIMACS
Hi @advaitranade
Please refer to the following link for the most current details about porting:
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
(EDIT:  note @kb_mv response above - you may wish to jot this number down, it's possible the post will be removed as the number is less than welcome in the public forums and is being removed by Public Mobile when noticed...)
kb_mv
@advaitranade You can call the number below of the Telus Port team. Explain the problem, they can fix the port. It might be advisable to call Freedom as well and see how else you can authorize the port. Maybe do that before you call the number below.
1-x
JK8
Your port is not complete. Contact  a moderator:
You can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
