nokia lumina 625-apn settings
mcmcyeo1
I am having difficulty loading the apn settings for my Nokia lumina 625. In fact I'm not sure that I have the right settings.  I can search the internet but cannot open my Facebook or Sykpe app.
8 REPLIES 8
mcmcyeo1
Thanks so much for all your help. I'm quite impressed with the quick responses.  Love Public Mobile.
@will13am wrote:
@mcmcyeo1, it's probably time to switch to iOS or android.  Even a die hard like @ShawnC13 is no longer using windows phone.
There are things I do miss but with Android you can basically still get the Microsoft experience.  Launcher 10 is a great launcher if you want the same layout and I think Microsoft apps are the same if not more polished on Android
will13am
@mcmcyeo1 wrote:
Windows 8.1
I went into the store and could not find a Facebook app to update and the Skype app said it was installed and I assume there is no update available.
Here is what I got back from the phone MVP
Skype for sure is a no go. FB should be fine through the web (probably better)
@mcmcyeo1 wrote:
Windows 8.1
I don't know anyone on 8.1 anymore I will send a message to my Insider group as we have a few Microsoft MVPs in the group
mcmcyeo1
Windows 8.1
ShawnC13
or Sykpe app.
Windows phone? What os are you running?  It could be out of date apps.  Both of those apps I had issue with when running Windows Mobile
will13am
@mcmcyeo1, please refer to the following knowledge base post on APN settings for this service.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
