no service
11-15-2022 03:29 PM
My phone was to be activated on Monday but six number code will not be accepted! please explain why I do not have service yet! must be your mistake with wrong code. I have checked the email repeatedly but code is erased as soon as typed in! Not impressed by no service so far
Service
11-15-2022 04:25 PM - edited 11-15-2022 04:25 PM
@BKNS27 wrote:Did you port your old number to PM or did you pick a new number?
Try rebooting the phone by powering off the phone by holding down the power button and power off then back on.
Whether the customer ported a number doesn't play a a part with the customer not having service. Even if the number porting has not been completed (or failed), there should still be Public Mobile (outgoing) service.
11-15-2022 03:46 PM
11-15-2022 03:32 PM
@tophat You'll need to submit a ticket via chatbot and ask customer support for assistance here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket then you can send a private message to CS_Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
