06-03-2026
10:16 AM
06-14-2026
10:32 AM
Dunkman
why does my phone show no service when both incoming and outgoing calls are fine?
06-03-2026 10:20 AM
hi @Diane33
does data work?
make sure you have no other sim card or esim. if you do, remove the other sim card or disable the other esim (like travel esim)
and try Reboot phone and click Reset network settings
