no internet connection
marek1
Moved  old SIM card to new  phone UMIDIGI f3S ( unlocked) and no internet connection.
Timer
@marek1
tried your SIM card in other deivce is working fine,
then those brand device need to do factory reset  How to Factory reset.
Yummy
Does other services work? SMS/calls?
Check if DATA is On.
@marek1  hi there, do you mean internet or data? Does calling and texts work okay?
It data, try 1 or more of the below:
  • restarting your phone with sim insde
  • toggle into / out of airplane mode
  • remove and reinsert your sim card
  • perform a reset of your device's network settings
  • check apn settings: https://apn-canada.gishan.net/en
dust2dust
Did you turn on mobile data? 🙂 Do you have data left to use? Likely a problem with APN. Are you able to edit or add APN settings?
