09-13-2020 06:30 PM - edited 01-05-2022 01:12 PM
I activated a new sim 3 days ago and can send but not receive incoming calls. During the activation process I requested porting in of my old mobile number from Bell . I entered my Bell bundle account number and maybe this was not the actual mobile account number. I guess im unsure if the porting actually went through because it has been three days but yet i can still make calls. I also cannot find my old Bell sim card. I attempted to submit a ticket but after entering my account info the "Next" box remains greyed out and unclickable.
Joining Public
09-13-2020 07:22 PM
FYI
Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for moderator to investigate. Moderator wait time is from couple of hours to couple of days. https://publicmobile.ca.ada.support/chat/
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider. You can continue to use the old provider SIM card until it stops working which is the indication that your number was released to PM.
After waiting for 3 days, your port request is stuck. Follows the instructions from above posts to get moderator help to finish your port.
09-13-2020 07:22 PM
Its a Samsung Galaxy A8
09-13-2020 06:43 PM - edited 09-13-2020 08:03 PM
@gmwindsor what's the make and model of the device?
reset your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
09-13-2020 06:42 PM
@gmwindsor wrote:I attempted to submit a ticket but after entering my account info the "Next" box remains greyed out and unclickable.
@gmwindsor you can also send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
09-13-2020 06:37 PM
09-13-2020 06:32 PM
@gmwindsor wrote:I activated a new sim 3 days ago and can send but not receive incoming calls. During the activation process I requested porting in of my old mobile number from Bell . I entered my Bell bundle account number and maybe this was not the actual mobile account number. I guess im unsure if the porting actually went through because it has been three days but yet i can still make calls. I also cannot find my old Bell sim card.
contact a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue port incomplete
you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
