No call problem
Wei1155
@CS_Agent, my phone cannot call out and no incoming as well. Says server error. Reboot already, no success.
hi @Wei1155
Pixel 7 should be good and not affected by the Telus change.  Check if you have VoLTE toggle, if so , enable it (but no worry if you don't see that, it is usually turned on but hidden by the network)
And did you just start the service with PM?  if so, make sure your old sim card are removed, old esim are disabled.  You should only have PM esim there and only PM esim enabled
and as said, reboot phone and Reset Network settings
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Wei1155
I am using esim card.
Wei1155
I am using pixel 7, in Ontario. Rebooted. Still no. It says I don't have active plane. But I do have.
hi @Wei1155
did you try reboot the phone and reset network settings? and did you try your sim card on another phone?
what phone do you have?
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City.   Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
So, if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted
On the other hand,  if the phone has 1900 Mhz,  or it is a Canadian/US model,  it likely won't be impacted and won't see service degraded
https://www.publicmobile.ca/en/get-help/articles/850-turndown
