no data at all after purchasing the new plan
hensiiie
just activate a new sim with new plans and phone number
but theres only incoming and outgoing call is working.
150mb purchased but doesnt work at all.
i only stayed here for 3 days so i purchased 10 days 150mb with province talk.
anyone can help?
using unlock iphone6
11 REPLIES 11
Rockdaddy22
I'm so happy everything's working great now, is your phone running iOS 10?
hensiiie
no dont have a dual sim, just different sim cards need to install APN. thank u though
hensiiie
it works now!!thank u so much !!!!
imm1304
Do not touch the Enterprise app.. thats probably important and not interfering with your data access. The cellular profile should have shown one for PM as well.  Thats the one you should delete because its easy to get it back when you insert the Japanese sim card back in.
So delete the Japanese carrier profile and then update to PM via software update.
ute1978
@hensiiie wrote:
not sure if thats what you mean,
i do hav this installed for my another simcard in japan.
and an enterprise app for my work.
for the about info,
carrier is public mobile 25.0
version is 10.0.2
have been reset the setting but as the first picture i posted,
theres only personal hotspot and the address is isp.mb.com
That means you have a dual sim phone and you are using another sim card?
Try swapping the sim cards in the slots.
hensiiie
for the about info,
version is 10.0.2
imm1304
Go into settings -> about and check both iOS version and carrier. Check for updates.  Did you try this?
Also Reset the cellular settings.
Usually the carrier update is sent that would install the APN settings automatically.  If you have other carrier profiles in the settings, delete all the profiles and then check for carrier update again.
hensiiie
yes i did everything i could, still not working....
Have you tried restarting your phone, or removing and inserting your SIM again?
hensiiie
hi, theres no such details on my apn setting, only the personal hotspot.
also, i had same plan before, it was totally opposite, data worked but phone call didnt work.
please help!!!
imm1304
Hi @hensiiie!
Welcome to PM!
Sometimes, you have to manually enter the APN settings before you can access the data network.  You can check the software update on your iphone 6, you may already have a carrier update from PM that you can install.
If not, here is how you can set up your data access manually:  http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update-and-APN-settings/m-p/1610#...
