new phone no voice mail
simonguillot
i just upgraded my phone and now voicemail is not working anymore
this is what i get when i call voice mail
"your call cannot completed as dial
check number and try again
or call *611 for support"
please help
10 REPLIES 10
 @simonguillot : And the callers can go to voicemail? ie. leave a voicemail ...and you get it?
Always great to hear that issue is resolved.!!
simonguillot
I meant it works well now
I press 1 and get to voice mail
Thanks
 @simonguillot : What do you mean "working the way it should not"? Can you press and hold the 1 key to get to your voicemail box now?
simonguillot
thank you all for providing direct number to voice mail and suggesting to change it manually in the phone
it is working the way it should not
 @simonguillot : There should be a setting in your dialer to set the voicemail number. On my Samsung A31 on Android 11 open the dialer, 3 dots upper right, Settings, Voicemail, Voicemail number.
simonguillot
KEY #1 has always been configured to work to call the VM. why it stopped working ??
 ... how do i make it work again ?
simonguillot
i tried to reboot once more and still no luck
tried accessing when holding key 1 on keypad, and it does not work
works when calling directly number VM # 778-581-4001
how can i resolve this? or reprogram the phone number on key number 1
 @simonguillot : What happens when you dial 17785804001? You need to set one of those voicemail access numbers in your phone for call forwarding and to access it.
@simonguillot  try reboot it once more .  It usually comes down with the network.
Worst case, you can manually set  it up using one of the local access number:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Updated-list-of-Voicemail-Access-N...
