02-10-2020 03:14 PM - edited 01-05-2022 09:26 AM
So I am getting a new phone number does that mean a new account and what of any balance that there might be is it gone or transferred
02-10-2020 06:23 PM
when i called says not in service but am working with a moderator
02-10-2020 06:21 PM
I did a reverse search on whitepages and thats where I found it I called it and its not in service, when it got ported my service was suspended phone doesnt work in order to get it back its between Telus and PM's fraud division in the meantime I inquired about a new number and PM is sending a new sim
02-10-2020 03:29 PM
@scapper1 wrote:somehow my original number somehow got ported to telus and i asked about a new one
Are you in control of your original number now at Telus?
If it was moved over to Telus then you could probably get it back.
Does your PM SIM and service still work?..just a different number now...or is it dead?
02-10-2020 03:29 PM
02-10-2020 03:28 PM
working with a moderator waiting for fraud division to call
02-10-2020 03:23 PM
02-10-2020 03:23 PM - edited 02-10-2020 03:24 PM
02-10-2020 03:22 PM
If your number was ported by mistake to Telus, create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
02-10-2020 03:22 PM
02-10-2020 03:21 PM
getting a mew sim card
02-10-2020 03:20 PM
02-10-2020 03:19 PM
If you are simply changing your number or porting in a numberin self serve the only thing that changes is your number.
02-10-2020 03:18 PM
You can change your phone# in an existing account.
To change your phone number: sign in to Self-Serve, select ‘Change Number' under 'My Profile' on the Overview page. Here, you can choose to select a new phone number or to transfer a wireless or wireline number from another provider.
Are you setting up a new account or do you have an existing account ?
02-10-2020 03:18 PM
@scapper1 wrote:So I am getting a new phone number does that mean a new account and what of any balance that there might be is it gone or transferred
No. You can change your phone number once per 30 days. You are still using the same account and same SIM card. Nothing is changed except your phone number only.
02-10-2020 03:18 PM - edited 02-10-2020 03:19 PM
02-10-2020 03:17 PM - edited 02-10-2020 03:19 PM
@scapper1 Did you change your number from with your self service / my account ? You are allowed to change it once per cycle. Then your balance remains and you lose nothing. You do not have to change your account to change your number.
02-10-2020 03:17 PM
There are uncertain wordings in there. What exactly are you trying to do?
