08-03-2022 09:58 AM
I just switched to a 4G plan effective immediately. But I'm still getting download speeds below 3 exactly the same as my 3G plan. What's going on?
08-03-2022 10:14 AM
It usually takes up to 48 hours for 4G to become active.
You can do speed test to confirm 4G but it might use a lot of your data...
08-03-2022 10:12 AM
@Hchlebek It take around 48 hours for PM to change the speed.
If you are running speed test, test it again 48 hours later as a speed test could eat up data fast
08-03-2022 10:05 AM
@Hchlebek Hi it takes up to 48 hours for the new speeds to kick in
