network problem
Ellis123
I switched from another company to your company to use. My plan is $25, but my data has been unavailable, personal hotspots have not been available. I have been using your company for 2 months, and I can’t solve my problem until now, please help quickly I solved my network problem and it has caused me a lot of trouble,
My mobile phone model is SE, I hope to find a solution suitable for me
8 REPLIES 8
@benfatto wrote:
@Ellis123  Be sure wifi assist is OFF, otherwise you may use cellular data even while on wifi.
I believe that data has never worked. Turning on or off Wi-Fi assist wouldn't cause that.
Shutdown
Your APN setting is probably wrong.
Naepalm
"I can’t solve my problem until now, please help quickly I solved my network problem"
You have issues for two months trying to get the network to work?
Here are some things you can try:
1. Power off your phone, remove your SIM card ,and wait one minute. Then put your SIM card back in and restart.
2. Check your APN settings
If you are still having problems your best bet then is to contact the moderators. you can do it through the BOT or by sending a private message through this link:
@Ellis123
We assume that your talk and text works?
If network reset did not help, you can also try the following
reboot phone
toggle airplane mode on, then off.
turn on cellular data
You can also try the SIM card in another working phone.  This helps determine whether hardware setup issue versus PM service problem.
benfatto
Triguy
Check your self serve account under data and add-ons to make there is an amount appearing.  If no amount is shown you have used up your data.  Try rebooting your phone.
gblackma
@Ellis123 reset your network and restart your phone if it doesn't automatically do so.
to reset the network settings on my Apple iPhone
  1. Touch Settings.
  2. Touch General.
  3. Scroll to and touch Reset.
  4. Touch Reset Network Settings.
  5. Touch Reset Network Settings.
  6. The iPhone will reboot. Once it turns on, the default network settings will be restored.
Enable data, sms and mms to send and receive from Android phones. Try sending an mms message. Welcometo the community. Stay safe.
RossN
@Ellis123 hello have you tried to do a network reset?
