03-24-2021 06:10 AM - edited 01-06-2022 01:33 AM
I activated my sim card yesterday, online. I then got a SMS message from my existing carrier and I replied yes I wanted to port my existing number over to the new carrier. I then put the sim card in my phone and turned it on. The screen says the network is locked and asked me to put a network unlock pin. My phone is not locked, is that what its actually saying. It tried the 4 digit pin I created , no luck there
03-24-2021 02:46 PM
@blacouture wrote:it working now please disregard the last request
Hi @blacouture Welcome to Public Mobile!
Always good to hear that a fellow customer's issue/problem is resolved. Yay!
If you have any further questions about your PM service, just ask
Have a wonderful day
RosieR
03-24-2021 01:03 PM
03-24-2021 07:59 AM
Its working now thanks
03-24-2021 07:58 AM
03-24-2021 07:58 AM
03-24-2021 07:46 AM
The device is locked with a previous carrier. You will need to contact them and to request that it be unlocked.
03-24-2021 07:41 AM
ok ty😊
03-24-2021 07:28 AM
@blacouture The IMEI isn't an unlock code. Ask the old carrier for the unlock code give them the IMEI so they can look for the unlock code.
03-24-2021 07:26 AM
I put in the IMEI (dial *#06# to get it) and it still does not allow me in
03-24-2021 06:20 AM
@blacouture wrote:I activated my sim card yesterday, online. I then got a SMS message from my existing carrier and I replied yes I wanted to port my existing number over to the new carrier. I then put the sim card in my phone and turned it on. The screen says the network is locked and asked me to put a network unlock pin. My phone is not locked, is that what its actually saying. It tried the 4 digit pin I created , no luck there
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
Find you PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you.
If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
