06-08-2023 09:07 PM - last edited on 06-08-2023 09:21 PM by computergeek541
so just got my sons sim activated and we put it in his phone and its saying network locked sim enter code?
06-08-2023 09:14 PM
You have to ask the carrier where you got the phone from for the carrier unlock code.
(PM would not be able to help with this)
and If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased|
06-08-2023 09:12 PM - edited 06-08-2023 09:13 PM
The phone is locked to a previous provider. That was the S5 right? Contact Samsung and they will be able to unlock it for you.
Adding - Nope. different thread. Contact the previous provider to have them unlock it for you.
06-08-2023 09:08 PM - edited 06-08-2023 09:25 PM
@Scypher0th Please reach out to support to get fixed
Message support directly
add @Scypher0th sorry my reply was wrong , as @softech @and @dust2dust mentioned phone needs to be unlocked from the carrier it came from
