need the IMEI number form an old phone
Moise
its from a Galaxy Samsung S9 Plus
fawkes40
I ended up having to call Samsung to get my IMEI number. I needed the Serial Number and I had to call them from a phone that was working to do it. I hope you can at least find the Serial Number somewhere in your records.
@Moise try these sites
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
and may  I know why you need it? you just lost the phone and need blacklist it?
Moise
its a phone I dont have no more
@Moise you have the phone on hand??
if you do, Dial *#06# on the phone
or check the box that came with it
if you lost the phone, you will have to check Google or  Samsung Findmy sites
@Moise @Go into settings and about phone
